is there a reason why, when i run optimization via the script in the command file, the hyperworks solver view doesn't pop up? The solver view only shows up when i manually click on run options> OptiStruct
Could you show your script?
I may fix to pop it up.
Here you go. That's the script i'm trying to get work. thanks.
