seperate faces to different components, view cut through component
I just started to work with HM and have two questions:
1) I do have a flat solid with variable thickness. Unfortunately, I am not allowed to share a picture of such a component. You may imagine a deformed piece of orange peel with some holes.
I want to seperate the inner and outer surface and organize both in different components. Both inner and outer surface are built of several faces.
I tried with Geometry -> Organize -> Surfaces and select surfaces 'by face'. However, that selects almost every face of the entire component.
Is there another way to collect the faces of the inner/ outer surface different than selecting all (about 100 little faces) manually?
2) Is there a way to view a cut through the component? I couldn't find anything related to that in the help.
Many thanks in advance.
Cheers,
Franziska
Hi Franziska,
Go to Tools>Faces, select the component and click find faces. After this you can select element by face.
Go to Post>Hidden line option, user can select the plane and check trim planes option so that the model is masked so that only the parts beyond the cutting plane is displayed.
0 -
Many thanks for your answer, George.
Unfortunately, I do neither find Tools>Faces in Tools nor Post>Hidden in Post.
