Submitted by dnethaji on Sat, 04/07/2012 - 22:12
Recently i have bought DRV C2 8412 kit, while connecting the h/w with XDS100 JTAG, i am facing so many problems.
- C28xx: Error connecting to the target: (Error -1135 @ 0x0) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.0.663.0)
When i run DBJTAG, i got following error :
The JTAG IR and DR scan-paths cannot circulate bits, they may be broken. An attempt to scan the JTAG scan-path has failed. The target's JTAG scan-path appears to be broken with a stuck-at-ones or stuck-at-zero fault.
At last i got following error while running the program that :
unrecoverable error.
Kindly help me pls
