Hello EDEM team,
I am currently conducting a survey of hardware (CPU, GPU) for simulations of a large number of particles. I have a chance to test EDEM 2021.2 on a system with GPU RTX A6000, and here is the result:
As you can see, If I select CUDA solver single precision, the performance is the highest. It is much higher than that of OpenCL.
My questions are:
1. Does this result reflect the current performance of the EDEM code?
2. It seems like the CUDA solver has not supported multi-GPU yet, so if I use OpenCL solver and want to gain the performance as the case of CUDA FP32, I have to use a multi-GPU setup, right?
Thank you very much for your time!
