How to output residual in Hyperview
Hi All,
I'm doing nonlinear quasi-static analysis in Optistruct. in order to better undestand the convergence of the simulation (expecially in case of non-convergent solution), it could be helpfull to output the residual in Hyperview. Is there a way to do this?
regards,
Luke31
Hi Luke31,
Residual can be seen in .out file.
I will check if there is any other way to represent in HyperView and will update to you on same soon.
0 -
thank you very much!
0 -
Dear @Prakash Pagadala,
Do you find how resolve this issue? I really need that.
Best regards,
Luke31
0 -
thanks!
For me could be also sufficient to understand where the maximum residual is applied. is there a way to understand it from the .out file or this is related to the issue of representing the residual in Hyperview?
Thank you for your patience,
Luke31
