Hi everyone,
I am trying to simulate a fluidized bed reactor to evaluate the effect of different particle shapes. The same simulation setup (only different particle shape) run very well with multi-spherical particles but not with polyhedral particles.
At the initial time when the particle volume fraction is not high (released from a factory), FlUENT (with DDPM turned on) ran smoothly. As time goes on, the particle volume fraction got higher (e.g. more particles at the bottom), the continuity equation in FLUENT is gradually hard to converge, and then "floating-point exception error" appeared.
FYI: I used EDEM 2021.0 & FLUENT 2021R2. For more information about its setup, please check the attached files.
Thanks for your reading.
