Create Mesh
Hey,
A longer time I didn't work with Hypermesh and now I don't know how create a mesh of the attached models. The tooth ft in the PDL and I just want it as the attached picture (capture). But I have problems with the triangle size and test them both togehter. Can you help me with that?
Hi
May i know, what are you trying to do with this model? (purpose)
Thank you
0 -
Hey!
This is a real simplification of a tooth and we trying some loading scenarios with different shapes.
Best,
Max
0 -
Go to automesh panel > set the selector to 'elems' > select displayed elements and > change the size of the mesh as desired > click mesh.
For finer mesh you can try changing the element density value.
Thank you
0 -
Thanks!
But than I have the problem that are the shape of both are a little bit chaning and after this they don't fit togehter what mens that they have penetration in each other.
How can I fix this problem that they have perfecting matching surfaces?
0 -
Can you share the latest meshed model?
Thank you
0 -
Sure and thanks /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
0 -
I don't see any change in size and the mesh also looks good. Can you please specify your problem with some pictures (Snap shot)?
Thank you
0 -
The problem are the contact surfaces of both the program says that they have some penetrations. And also for the PDL test the triangles on the where you can look inside are realy small.
I wnat want to equivalence the contacting sorfaces of both parts that I can estimate the loading rtansmission into the different parts. Any ideas how to fix it?
The attached picture shows the problematic regions I think.
Do you have any ideas?
Best,
Max
0 -
maximilian_bemmann,
The model which you have shared with me, in that i don't see any gap between both the surface as you shown in the above image.
Please can you share the right model?
Thank you
0 -
Hey you are showin just the tooth model without the second one. Right?
Best,
Max
0 -
Best,
Max
No.. both together.
0 -
Ok then a second. /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Now are ne newest version inside.
0 -
again i got the same model. may i know which version of HM you're using?
0 -
What is the error message you are getting when you try volume mesh?
Thank you
0 -
Thanks,
I don't know why but now it was also working I think I didn't give enough time.
Thank you very much /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
