I have done the modal analysis of rectangular plates. Each plate has same length and breadth but has holes at different locations. I want to compare the modeshapes of these plates by overlaying them.
When I overlay two h3d files, they appear with a 180 degree phase shift with respect to each other, i.e. the crest of one plate meets the trough of the other plate for every mode. How can I change the phase of one of the plates by 180 degrees?
Or is there any other way to correct this?
regards,
Vachan
