I have composite laminated cylinder. I want to mesh it with solid maps with transition into the center. Its very easy doing it by 2D elements but I can't handle it by 3d elements. My model and desired mesh is like attacted files. I cant merge the element between common surfaces.
Would you help me if you have any ideas?
Thanks alot
