Hello ! I am get this warning while trying to simulate a structure within feko
WARNING 37591: Non-radiating characteristic modes were removed
do you have any explanation to this warning ?!
Thank you!
hello @ALM
can you please attach your .cfx file to this topic so that we can take a closer look at what is generating the warning?
The Characteristic Mode formulation for dielectrics solved with the surface equivalence principle (SEP) results in a set of eigen modes that contains both internal and external resonances. The internal modes (sometimes call non-physical or fictitious) do not radiate any power, and are thus removed from the result set. It is advised to increase the number of modes requested when dealing with such models.
