I would like to import an initial geometry from Autocad to Inspire: I saved the file in .igs/.iges as solid but when I try to import into Inspire the geometry is a surface.
Can anyone tell me how to get a volume?
In a second moment, I discovered that when I try to import solid geometry with some surfaces, the solid loses volume and becomes a surface too.
I could be possible that different kind of geometry imported in the same model ( lines, surfaces, and volumes) do they create the problem?
Thank you.
