I've recently encountered a problem while trying to load a mesh. My analysis file used to take about 1 minute to load (surface mesh and small hexcore volume mesh) but recently it took almost three HOURS. It seems to be hanging on the reading elements stage. When it did finally load I deleted all comps and saved a test file. My test.hm (should be empty) was still 800kb+ in file size. When I launched HM and saved a blank file it was close to 500 bytes. What is being stored in my file? Is there any way to clean out that (potentially) corrupt data?
I'm using HM 11.0.0.132 and do not have the option to upgrade to 12 at the moment.
Thanks for the time, hope you have some ideas.
