Hi,friends and experts,
When I am simulating a not that electric large simulation model, FEKO always give me some error: not dynamic memory allocation.
I do check the reason. It was found that when goes to the precondioner calculation, it will need a a lot of memory. Also, different preconditioners may lead to different memory requirement.
So after goes to the No precondioner settings, there will be no problem at this stage. However, when goes to the iteration procedure, it will also have that problem.
Could anyone can help me with this problem? The model is attached here.
Thanks.
