Hi all,
I've been trying forever to delete this floating particle without luck. Im pretty certain it is lines and points (rather than elements and nodes).
Anyone know how to?
Hi George,
Have you tried the delete panel?
Press F2 (shortcut to delete entity panel). Select the lines and delete them.
If they are free edges, they will treated as elements (PLOT elements). Change the entity type to elements and delete the floating elements.
