I WANT TO KNOW HOW TO SOLVE THIS PROBLEM I KNOW PROBLEM IS IN JOINT WHAT IS SOLUTION? WHY ITS COMES LIKES THIS
Hello @syed shaeed sh,
Greetings!!!
Check the loading and boundary conditions that you have defined for the parts.
Also, did you properly follow the proper definition of Universal Joint, as shown in figure -
Also, do share the .key file with us.
Thanks & Warm Regards,
Akshay S.Patil
can u send full copy of book u have for ls-dyna solver? it will be very useful for me.
You could go through this link, and choose the appropriate manual version, depending on the LS-Dyna solver, that you are using.
Vol 1- Mainly for keyword definitions
Vol II - Mainly for Material models
http://www.lstc.com/download/manuals
