Visual difference
I'm perplexed with a visual difference problem.
I created a simple point or node that is located on a corner of a cube. It seemed on the corner, but it does not look like on the corner if zooming in extremely closely. I wonder if it is just a matter of visualization in Hypermesh, or the point or node is exactly NOT on the corner. Thanks!
Ryan
Hello Ryan,
mostly it is only a graphical problem (triangulation and polygonal representation).
You can try to increase the geometry refinement level. Press 'O' (options) -> graphics -> geometry refinement -> level x (try auto or > 2)
A second reason could be a shared edge with a large geometry tolerance or manually stitching. Try to toggle the edges to 'free' and take a look.
Mario
0 -
Thanks for help, Mario.
