Submitted by danilo.llano on Tue, 05/15/2012 - 19:10
Hello everybody, I have a problem and I will be very grateful if somebody can help me...
I'm using VISSIM to implement on a DSP a recursive algorithm for estimation (matricial operations principally) . My problem is that I need to set up initial conditions to start the algorithm and then use the last results for the next estimation but I don't know how to do it with VISSIM (the algorithm wil be implemented on a DSP by Texas Instruments, F2808). I was thinking in using the block merge, but I don't figure out which signal can I use for the boolean condition. This signal has to set up the initial conditions every time the algorithm starts. Any idea???
Thanks a lot for the help
Best regards, Danilo
