how can i extract the density value of each element after a topoly optimisation result toward an Excel table for example ?
Best regard
Hi @Meshing
Please use Control Cards>> DENSITY>> FIle format>> TOPO to output density for elements of Design space.
Please i could not found the file format TOPO ?
Can you help me please i cant found the TOPO option in density control card
Thank you very much
Use file format H3D. You will get the density of each element.
Thank you
HI @Meshing
If you are still not successful, try this...
DENSITY,H3D,ALL,TOPO,ALL
Add or replace above line in the solver deck by editing in any text editor and check if that helps.
