I was use detach feature to detach one element from the other so that they are no longer connected. But how to ensure that the elements are detached, before proceeding for analysis?
Hello @S R Arun,
Greetings!!!
You could check it by using the tool Edges.
It could be found in Tool>Edges or Shift+f3.
Change the tolerance value depending on your model, and check for PREVIEW EQUIV.
If nodes are highlighted, then they are not attached.
Thanks & Warm Regards,
Akshay S Patil
