Submitted by Joe on Fri, 09/30/2011 - 02:52
I think VisSim doesn’t like the fact that the speed variable, which is downstream from the NOT block, is wrapped around to be one of the inputs before the NOT block. In a strictly digital simulation, this could cause a problem, but even then, you could have examples where outputs are wrapped around to eventually be inputs to a given logic block (e.g., a SR latch).
At any rate, if I ignore the warning message, the simulation works just fine. My question is, is there any way to tell VisSim not to display this warning message?
