Advanced boundary conditions
Updated by Altair Forum User
Hi everyone,
I have a question regarding the boundary conditions. Is it possible to define translational boundary conditions which only act in one direction? So for example only in the positive X-direction and not in the negative X-direction. So that these regions can only transfer compression and separates if put under tension. This means that the reaction force can only work in the direction of the object and not in the opposite direction. Is this somehow possible?
Regards, Mike
1 - 4 of
41
I'm not sure about CGAP elements. But a CGAPG element should do the trick.
Thanks for the input, I will give it a try and let you know.
Regards, Mike
It looks like a contact condition?
