How to correct the RBE3_CBUCH stiffness matrix between to assemble 2Dshell to 3Dsolid
I want to realize an assembly between 2D shell END 3d SOLID BODYwith bolts
i could delete the dof 4 5 6 of the solid body
but i have k1=k2=k3=0 for the CBUCH element !
How to correct the RBE3_CBUCH stiffness matrix between to assemble 2Dshell to 3Dsolid (K1=K2=K3=0 .. this is fault)
Thank you
Can you please be more clear. What do you mean by you need to correct the stiffness matrix between the 2D and 3D part?
0 -
thank you for your reply,
when i want to assemble the 2D shell with 3D solid body using RBE3 ( Bolt ) i should delete the 4,5,6 DOF
i did that
but the CBUCH element (between 2 RBE3 ) it have stiffness k1=k2=3=0 !! this is not right
so i dont know how it can be corriged automatically
0 -
You have to enter the values manually or you can make the element RIGID.
There is no way of getting the values automatically.
