I'm working through several Hyperworks youtube tutorials and I found one that converts an object of varying geometry into 2D surfaces via mid-surface function; and then he proceeds to connect them.
https://www.youtube.com/watch?v=-Y5XUJrqNtg
My question stems from a time in the video (15:30) when the author begins to connect the 2D mid-surface meshes together and assigning particular properties. Please watch the video it just takes a minute.
I don't understand how the connecting surfaces (perpendicular to the main surface) can reasonably assume the main surface properties - namely thickness. Is this practice more of a convention?
Appreciate the help!
JP
