hello ,
I wanted to mesh this solid in 3D tetra my teacher advised me that for the ends in the form of hollow cylinder (for the connections) I can not model them it will have no impact on the static calculation only thing that should i do is to replace them by A point mass for this I must calculate the center of each cylinder then create a node and attach it to the rest of the mesh by rigid elements. Then on this node apply a concentrated mass equivalent to the mass of the cylinder. This will simplify the mesh without losing precision. I do not understand how I'm going to do this on HYPERMESH and what does it mean by not modeling them should I delete them ?? if you can explain me more I will be grateful.
Best regards
