How can I check the orientation of all beam in an assembly at once.
or do I have to check it individually by reviewing at the bar update panel.
You can check orientation of beam by switch 1d representation to 'detail' mode
If you did not assign a beam section, it will show beam coordinate system
otherwise, it will show 3d representation of beam
@tinh thanks for the reply but the procedure you are saying is just for 3D representation and it just show that whether I have oriented my beam elements or not, it does not show whether the orientation is correct of not.
If you change orientation, the 3d shape of beam will rotate, so you'll know it's correct or not
Please try a rectangular cross section beam to see
