hello,
im doing a model correlation between an experimental results stocked in a UNV file, and a numerical simulation run using optistruct while loading both results from the UNV file and the h3d
i have a message the said << Node block 2411 or 15 or 781 does not exist >>.
this error comes from the UNV file and i don't know how to fix it.
thank you for your help!
