3D Tetra Elements not showing in LS-PrePost/DYNA
Altair Forum User
Altair Forum User
I imported my geometry into HyperMesh and used automesh to generate quads on the surface.
I then used volume tetra to generate 3D tetras and then deleted the 2D elements on the surface.
When I export my model to DYNA keyword file and open it in LS-PrePost, it is missing the extra pyramid elements at the surface.
E.g. 2D view in HyperMesh:
View of surface using mask option in HyperMesh.
Surface in LS-PrePost:
Any thoughts on why this is? How can I retain the elements at the surface?
Thanks,
Petros
  • tinh
    tinh Altair Community Member
    edited November 2018
    Shift F6 split quads into trias before tetramesh
  • QuyNguyenDai
    QuyNguyenDai Altair Community Member
    Pyramid elements are supported in LS-DYNA, but Hypermesh can not export them to DYNA key output.
    I have to play with template to add this element type.
  • Altair Forum User
    Altair Forum User
    Thanks Tinh, I don't want trias at the surface though.
  • QuyNguyenDai
    You don't want trias at surface and you can not make pyramid for your LS-DYNA. So what do you do now then?
  • tinh
    Maybe he want to keep quads as a cover comp
    @PetrosYou can split pyramids into tetras by panel 3d>split>solid elements
    switch to 'split into tetras'
  • Altair Forum User
    Altair Forum User
    Thank you both for your suggestions.
  • QuyNguyenDai
    Keep 'quads' at external faces and make 'tet' in internal volume? That does not make sense from point of view of FEA !!!
  • tinh
    Yeah, it seems to be not continous!
    Don't understand
