I have a 2D to 3D connection as shown in the attached image. Please guide me for this.
I think you can do it in shell with variable thickness.
Thank you for that sir! But what about connection between the two bodies? Should we merge the nodes at the connection or provide some connection? For the latter case what type of connection you would suggest me for an explicit analysis (in Radioss)?
