How to transfer and copy Mesh and Nodes from one Surface to another
Jan Grasmannsdorf_20379
Jan Grasmannsdorf_20379 New Altair Community Member
edited June 2021 in Community Q&A
if you would like to transfer and copy a mesh from one surface or component to another, please use these functions (described in the pulldown menu):
Mesh - Translate - Elements - if you would like to translate the mesh along an axis
Mesh - Rotate - Elements - if you would like to rotate the mesh at an axis
Mesh - Project - Elements - If you would like to adapt the mesh to a new plane
Morphing - Map to Geometry - if the mesh should adapt to a new (e.g. curved instead of planar) shape
To create a copy, make sure that you select the 'Elems - DUPLICATE' option in the yellow entity selector. For this you first need to select the original elements and then hit the yellow selector and select 'duplicate' to create a copy that will then be translated, morphed etc.
 Jan
  • Q.Nguyen-Dai
    Q.Nguyen-Dai Altair Community Member
    edited February 2020
    You make the question on the title of topic and you answer to yourself in body?
  • Jan Grasmannsdorf_20379
    That was a question from a user, that I received via mail. I publish my answer on the forum, so that other users might profit from this thread :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
  • Jorge_20631
    Jorge_20631 Altair Community Member
    edited June 2021
    Great tip, thanks !!!!
