What procedure needs to be followed while solving the model in AcuSolve?
Following is the procedure followed:-
1. Opening the model in Hypermesh
2. Surface Meshing
3. Exporting the model in required format
4. Opening the same in AcuConsole by saving the model (changing the dimensions as “mm” is default option in HM and “m” in AcuConsole)
5. Volume meshing
6. Giving Boundary Condition
7. Solving the same
8. Checking the plots and graphs in AcuProbe and AcuFieldView
