compatibility of mixed mesh with the explicit analysis
Hi Amar,
The compatibility depends on the model complexity. User has to check whether the load transfer is successfully happening between these element configurations.
Thank you George sir!
How one can ensure that? I think, since the pyramid elements are automatically generated at interface of the two configurations (hexa and tetra), all the nodes should be connected there. So why do we need to check the load transfer?
HI Amar,
As a general note it was mentioned. Ensure the connectivity and you can continue.
I am using HW 12.0 Radioss. When I go to Toolbar->mesh->assign->element type, I see that only pyramid5 elements (in 2D and 3D page) are available (See the attached image). Does it mean that only 1st order pyramids could be generated at the interface of the hex and tet mesh?
Hi Amar,
