I need to sync two PWM units 180 deg out of phase. How is this done? The system has a total of 12 PWM units. The current design needs to sync unit 1 and unit 4 180 deg out of phase. Is this done in the ePWM pull-down window? I am using an F280049 with the BETA 2019.1 software. I have the PWM units working with all synced at the same start. One other design requirement is to hold one PWM signal high and one low for 8.333ms. Then return to a high frequency PWM. This design is for a 60 Hz inverter.
