is there any possibility to define a contact (line or Point) between two volumes? Or is a little distance between two independent volumes necessary?
Thank you.
In your case, you need to use a face as a contact between two volumes.
Best regards.
Thank you for your Response.
But how can I use a face as a contact?
I always get face/line intersection or sth. else.
Hello, In your case, you need to use a face as a contact between two volumes. Best regards.
Thanks.
