I want to import an IGES-file. But when it works, it only loads to 65 % and then the flux-program shut down.
What can be wrong?
There doesn't appear any error or warning or sth. else.
Thanks.
When you import your IGES file, you use the modeler?
Can you send us your IGES file?
Best regards
thanks for your respond. I already solved this Problem. Are there any conditions which the CAD-Geometry has to comply?
Because in the CAD-geometry were only faces. And after converting it into solids it works.
Can't Flux deal with face-geometries and it always has to consist of solids?
Thank you.
