I have plotted data in POSTFEKO with API scripting, but I do not know how I can export each graph as a .dat file. Can someone help me with that? And is there a macro recording option for POSTFEKO, because I could not find it. Thanks in advance!
With kind regards,
Meerten
Hello Meerten,
The Graph object has a method to export traces. Below is an extract from the documentation.
ExportTraces
Export the graph traces to the specified tab separated file.
If you want to loop over all the graphs and export the traces to .dat files, I suggest that you create a FOR loop and loop over all the graph collections that you want to export and then export use the method above. It will be something like the code below:
app = pf.GetApplication() for ii = 1, app.CartesianGraphs.Count do local graph = app.CartesianGraphs[ii] graph:ExportImage('Cartesian_Graph'..index, 100) end
This is just for Cartesian graphs. You will need a similar loop for other graph types that you want to export (polar, Smith, etc.)
Note that I didn't test the code. /emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20'>
Hi Jif,
Thanks for the quick and great response! I've got what I wanted, many thanks to you!
Hi Meerten,
Macro recording in POSTFEKO is still under development, too early to give an estimation when it'll be available.
@Torben Voigt That would be great!
