Adding a source in postfeko
Altair Forum User
Altair Forum User
hi.. good morning..  i need to add an source to the result(i.e in postfeko).. its nothing but giving a source to the object and verifying how it works... in postfeko, i came to know one option.. but i dont know how to write the code.. please go through the images and help me...
  • Madelé
    Madelé
    edited October 2018
    Hi tejaswi
    Can you please clarify what you mean by 'adding a source to a result' in POSTFEKO? What are you trying to do?
    From your photo, it seems that you have a looped plane wave source in your model. You can add a plane wave source to the 3D view, but you cannot access the source data of ideal sources like plane waves (refer to the FEKO User Manual section on 'Source Data' for the quantities that are available for the different source types).
    Kind regards
    Madelé
  • Altair Forum User
    Altair Forum User
    edited October 2018
    hi.. thank you for your response.. i read the user manual about source data..you said about the existing sources  .. but i am not asking about the existing sources..
    i just want to add a new source like double exponential signal... i just know only one  option in postfeko to add a source by using math script.. that's why i am asking how to write code for adding a source.. could you help me plz..
  • Madelé
    Madelé
    edited October 2018
    Are you interested in doing a time analysis and you want to define an input time signal (double exponential piecewise pulse)? If this is the case, you have unfortunately run into a current limitation of the software. It is not yet possible to do this through scripting, so you would have to perform the time analysis manually.
  • Altair Forum User
    Altair Forum User
    edited October 2018
    hi.. thank you for your suggestion. it helps me a lot... finally i did it. thank you ...
