I am new to HyperMesh and I am trying to create an 'entity set' containing many elements. So I go to : 'Analysis' -> 'entity sets' -> 'entity: elems' -> 'elem list'. What is the rigth way to select the element list? All I can do is select the elements one by one with the cursor, which is time consuming.
Is there a better way to select the elements? Usually, when I need to select elements, there are many ways of doing it: by ID, by plane, window, etc. But for the entity set, I cannot choose a selection method.
Thanks
