Submitted by Joe on Thu, 09/09/2010 - 23:41
I need to create a counter that goes from 60 to 0 then restarts at 60 again, decreasing 1 with each time step. How would I make something like this? Thanks, Joe
Submitted by Anders89 on Thu, 09/09/2010 - 23:44.
No problem. Find the VisSim diagram attached below (if you are signed in). If you right click the counter, you can change the count restart value. The VisSim/Fixed-Point block set (included with ECD) includes a number of up/down resettable ramps and counters.
Submitted by pcavanagh on Fri, 09/10/2010 - 22:50.
This counter uses the expression block to reduce the number of blocks for resetting the counter.
