Hi there,
when I was trying to visualize the belgian_block.crg road file from OpenCRG using the Road Tools of MotionView, the Input File Error 'utf-8' codec can't decode byte 0xfc in position 18... occurred. The simulation goes well with this road file, just the problem with the road visualization. Hope someone would know how to fix this issue. Thanks a lot!
Regards
Feifan
There could be unrecognizable characters in the CRG property file.
Please delete all the lines under $CT (comment section) and try again.
There could be unrecognizable characters in the CRG property file. Please delete all the lines under $CT (comment section) and try again.
Oh god it works. Thanks a lot!!
Best regards
Feifan Li
