Hi all,
As i wrote on the title, i would like optistruct find me the value of the force for a certain displacement.
For example, I a have a cantilever beam (let's says: 3D solid, hexa) and the maximum deflection I would like is:10mm. I would like to make a optimization analysis (i think its a size optimisation) which optistruct found the force from a range (says: [0N to 1000N]) corresponding to 10 mm of deflection.
Is it the right type of optimization ( SIZE one) if yes could u tel me how to make that ? i will be really apreciate
I set up it like that:
- Objectif: 'find value of force corresponding to 10mm of displacement'
- Constraint: u=10mm
- design variable: Force range from [0N to 1000N]
Thanks by advance,
Kodebar
/emoticons/default_happy.png' srcset='/emoticons/happy@2x.png 2x' title='^_^' width='20'>
