Automate node creation
I need to create nodes for elements of user specified sizes. For eg, If the user specifies size 6 for the element, the nodes should be created at (0,0), (0,6), (6,0), (6,6). If the user specifies size 8 for the element, the nodes should be created at (0,0), (0,8), (8,0), (8,8). This is to be repeated to generate a geometry 830 mm*450 mm . therefore, if the element is of size 8, 830/8 elements must be created along the length and 450/8 elements along the width with their corresponding nodes. Please tell me how to automate this? Also, I need flexibility to change 830*450 mm dimensions to user specified dimensions (say 500*250 or 1000*600 etc etc). How do I incorporate this??
thanks,
Kushal.
thanks,
Kushal.
You can create one big element with that dimension for example 830x450mm, do a remesh on that element with 8mm mesh size/all quads then get all the nodes.
Hi kushal
it is not possible to create element of same size within that dimensions i.e 830*450 until element size completely divide dimension 830 & 450
user specified size say 8 , does not divide 830 completely so every element size can't be 8..
#####Script
set length [hm_getint Length 'Enter the length']
set width [hm_getint Width 'Enter the Width']
set elemSize [hm_getint size 'Enter the element size']
set length_count 0
set width_count 0
while {$length_count < $length} {
while {$width_count < $width} {
*createnode $length_count $width_count 0 0
incr width_count $elemSize
if {$width_count >= $width} {
*createnode $length_count $width 0 0
set width_count 0
incr length_count $elemSize
if {$length_count >= $length} {
*createnode $length $width_count 0 0
*createnode $length $width 0 0
