Non selected surface
I must select the all of surface in the hole. I attached the pictures. Blue surfaces will be nondesign_surface. Half of the hole is pink which is design space. However it should be blue which indicates the nondesign area.But half of the hole which i marked red circle could not selected by manuel usuage. How can i select this nonselected surface (red circle area)?
Could you help me?
Please answer as possible you can,
Thank you
Your geometry is 3D (solid) and you're trying to define design/nondesign zones over surfaces?
0 -
Yes, one solid and the hole should not change after optimization ,so i want to define nondesign surface
0 -
F2>delete>solids to delete all solids then you can select the surfaces manually
0 -
This is for deleting solid? Because when i tried the surface, it is gone and i could not trim
0 -
When a solid existing you cannot delete surfs be cause they belong to the solid
0 -
When you work with solid elements, I think you have to define design/non-design area on solid elements, not surfaces.
0 -
I picked the components, and i did define thank you all attention
