*** ERROR # 2203 *** Error(s) encountered during element check ***** Element Quality Check Failed - error limits violation *****
Can you please be more specific? Is the "panel" (the function) not working or do you have elements which failed the element check? If it is the latter, what kind of check did you carry out (aspect ratio, warpage,....)
Thank you
Matthias
