I would like to do a normal mode analysis of a laminated glass. The construction is glass-polyvinylbutyral-glass. How should the laminated glass be modelled in HyperMesh? Should I use the OptiStruct solver or RADIOSS? Thank you very much!
Hi ETL,
Please use OptiStruct for normal mode analysis.
You can model using MAT8 material card.
