Submitted by sabrina_ akhwand on Tue, 05/01/2012 - 05:20
I am using the 2 month trial version of VisSim/ ECD v8.0 for designing controller that will work on TI , ezDSP TMSF2812 (Rev. C). I have developed the model in Vissim using the Fixed point tool set and have also successfully debugged it using the Vissim communication interface. I now want to download the code so that I can run it independently on the target. Please can you let me know the steps I need to follow in order to run the code independently on the target.
I tried selecting the Code Gen.. option in Vissim without ' Include Vissim communication Interface' , generated the code, compiled it and then clicked on the download button. As result of this I saw download complete verification appearing on screen. Now when I open the code composer studio , create a project and click on BUILD option I see ' Compilation failure 1 error , 0 warnings 1 fatal error detected in compilation: couldnot open source file ' cgen.h'
Please can you guide me on the procedure I need to follow in order to succesfully run the project in Code composer studio using the source code generated by Vissim.
Another point that I would like to mention here is that , in your ECD guide you have talked about some Vissim CCS PLUG-IN. The plug-in should works fine with any 3.x version of code composer studio.I installed Vissim after I installed CCS V 3.1 on my PC but when I open the code composeer studio I donot see any lower window pane with Vissim logo appearing on the side ( as shown on page 198 of your VisSim/Embedded Controls Developer User's Guide version 8.0). Do i need to download this VISSIM CCS plug-in in order to successfully open the vissim generated files in Code Composer studio. If that is the case please can you give me the link for its download as I donot see it on the Download page of your website.
Thanks Sabrina
