I know this problem has come up before, but I've tried troubleshooting this several times and haven't obtained any results.
I'm very new to this software and so I could very well just be doing something wrong in the UI.
The model is fairly simple. A solid c-channel cross beam with shell HSS that act as columns.
'*** ERROR # 2502 ***
Element 9 had incorrect node numbering sequence and needs renumbering.'
I've tried renumbering all elements, I've tried renumbering singles. I know PARAM, RENUMOK is defaulted as being on/YES, so I can't see that being the issue (should be noted I have no idea where to even find this). I've tried exporting the model and importing and that doesn't really do anything.
Any help is appreciated. Cheers.
