I tried to use the Files Atherton Model in Flux 2D. Therefor I designed a simple example and defined the five JA Parameters. During the solving is a mistake because it doesn't converge. Can you maybe tell me what is the mistake? I put the file below.
You will find attached your Flux project ready to mesh and solve. I did some modification:
Best regards.
