I am trying to optimize a model using Optimize pro, however, I am always getting the error as follows;
GRG232 6.06 Report: Date Mon Mar 29 17:21:18 2010
Problem Title: VisSim32 Version 7, Optimization by VisSim32 / OptimizePRO
FATAL ERROR IN VARIABLE BOUNDS: xub[11] = 0.12 < xlb[11] = 0.22
FATAL_EXIT: GRG2 terminated by a FATAL ERROR. INFORM = -1
Time used is 0.047 seconds.
Anyone have an idea?
Thanks
Brian
What is xub[11]?
Submitted by Anders89 on Tue, 03/30/2010 - 09:04.
xub = x upper bound, xlb = x lower bound. Your 11th parameterUnknown has the bounds swapped. The Generalized Reduced Gradient algorithm won't run until you correct the bounds situation.
