Hi all
How to create tabs in hyperview similar to hypemesh hm_framework?
I remember that I have given an answer about this. Can you search the post?
Hi tinh,
Thank you. I found from one of your post. Below is the command for framework in hyperview.
.mainFrame.center.f1.left_proj add [hwtk::pane .newTab -text 'New Tab']
did you type in 'text' or '-text' ?
