Hey guys,
is there a .tcl-command which shows the maximal node stress of a structure after a simulation?
Kind regards and thanks in advance
Simon
You can get the top 1 using Selection Set.
Here is example.
set type 'node'; #element or node# set t [clock click]; hwi OpenStack; hwi GetSessionHandle sess$t; sess$t GetProjectHandle proj$t; proj$t GetPageHandle page$t [proj$t GetActivePage]; page$t GetWindowHandle wind$t [page$t GetActiveWindow]; wind$t GetClientHandle ****$t; ****$t GetModelHandle modl$t [****$t GetActiveModel]; modl$t GetSelectionSetHandle set1$t [modl$t AddSelectionSet $type]; set1$t Add 'contour top 1'; set1$t SetLabel '$type set top 1'; ****$t Draw; tk_messageBox -message 'Top1 $type ID = [set1$t GetList]'; hwi CloseStack;
